Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
MacBook Pro not starting up and beeping 3 times
Hey guys,
I recently got some soda on my trackpad and it started going berserk whenever I’d be on my computer so I decided to open it up take out the trackpad and clean it.
I used rubbing alcohol and q-tips to clean the trackpad. After doing so, I put all the screws and parts back together and tried turning it on but all I get is these annoying 3 beeping sounds, a pause, and then continues beeping.
I saw some videos on troubleshooting this issue so I opened it up again, took out those two ram chips cleaned them with a soft cloth and then inserted them back in, same issue!
What can I do before submitting this to Apple and being raped on the damage fees.
Questa è una buona domanda?
Punteggio 0
1 Commento
Do you have a unibody or retina model??
The Unibody has replaceable RAM the retina doesn't but it does have a removable SSD unit.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Good news, Apple will not be raping you on repairs for this machine, because they won’t work on it at all:
https://blog.macsales.com/45147-apple-ad...
Punteggio 1
2 Commenti:
We’ll find out soon... anyone else have actual solutions?
da
Never mind, Dan is correct. You have given us the wrong machine in your device selection.
da
Aggiungi la tua risposta
shawn keshmir sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
