Salta al contenuto principale
Weber Grill Pressure Regulator Diagnosis / Replacement
Trying to figure out what is wrong with a older model propane grill made by weber. someone cranked on the plastic collar , attached to the pressure regulator with a wrench . i dunno why. I suspect the compression fitting i guess for the pressure regulator will not work correctly now , maybe cracked from using a wrench for no reason.
grill was working perfect before this now no smell of propane , appears to have no gas flow . Part of the problem is i dunno / remember what the model is . I have attached a few more pics below.
if i am correct , i just need a new pressure regulator , so if anyone has any ideas on what a “good” compatible model or just weber OEM one i could buy it would be appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See if helps nail down the problem Propane Grill Regulator & Hose Replacement
Do be careful! Propane does not have an odor additive like household gas does.
Punteggio 1
1 Commento:
i followed most of the info in this guide, having reinstalled the regulator, turning gas on and waiting and so on . Grill is now working, no model info on my grill afaik. so glad its working now , thanx for help
da
If I remember correctly, there were changes made in propane regulators about the mid-ninties https://www.google.com/search?client=saf...
Punteggio 1
1 Commento:
ty, i will try this, using the existing regulator over next few days , it not being OEM i dont have a part #. This partially why i am on ifixit to try and figure out which OEM or just good aftermarket regulator i might need . My grill is 5 flavorizer bar model with two controls on side , a few models it could be via this website: https://www.thebbqdepot.com/blog/which-w...
da
Aggiungi la tua risposta
Brian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,443
