Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
iPhone 4s (downgrade from 9.3.5 to 6.1.3) with jailbrake will work?
Hello, i have problem with downgrade iPhone 4s (it is no jb phone, all parts is original, never replaceced, never have problem with phone). I download version 6.1.3 ipsw and tryed do downgrade in iTunes on two notebook with win10 and one MacBook Air. Try in dfu mode, with only one device, in usb 2.0, with original cable, newest itunes version and 3utools. Result is one: it is stuck on bar progress at start and message in iTunes: "waiting for iphone” when i exit from dfu iTunes say that it is Error 9. In 3utools have message: „waiting for NAND %”
Error enable to restore idevice (-1)
I tryed on two oem apple cable (little demage) and one noname cable - with this cable i can restore phone to 9.3.5 version thats mean that its ok…
Please help.
Questa è una buona domanda?
Punteggio 0
6 Commenti
is this a phone you have had from 6.1.3? ie is the ios/ firmware on your mac or win10 machine? instead of downloading (which is a jb using 3utools) you may be able to access the old firmware on your pc.
da
This phone have ios 7 from factory
da
Its very very important thing for me, please help ! :)
da
If this phone came with iOS 7 from the factory, I don't believe it is possible to downgrade the OS. Even though it's the same phone, I believe Apple did something with the firmware or something that prevents OSes older than the one it shipped with to work. There is a similar issue with the iPad 2.
da
Ok thanks, so what can i do now i want ios6 in my IPhone 4s :(
i have too ipad2 when now is 8ios but from factory was 6, i ll try downgrade ipad by iTunes and see if it will work.
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You cant downgrade iphones to older versions if the phone has been updated.
With iPhone 4 and 4s it is doable but only if you have saved the SHSH blobs which are basically authorization keys that allow you to restore a certain iOS version that you either have or had previously.
Punteggio 0
1 Commento:
da
I don’t agree with the first answer.
Apple reopened iOS 6.1.3 for iPhone 4s, you can downgrade to iOS 6.1.3. But if your iPhone 4s is 8GB 2015, you can not restore to iOS 6.1.3, cause the default factory iOS version of this iPhone 4s is iOS 7.1.2.
Punteggio 0
Aggiungi la tua risposta
Mishka92 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 4,152
