Salta al contenuto principale
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 Domande Visualizza tutte
Batería de 5 cables
Hey! How are you?
I want to know why this battery has 2 black cables, 2 red cables and 1 white, because i wanted to put another kind of battery that only has 1 black cable and 1 red cable
Hey! Cómo están?
Quiero saber por qué esta batería tiene 2 cables negros, 2 rojos y 1 blanco, porque le quería poner otra batería que tiene sólo 1 cable negro y 1 rojo
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
my guess would be the 2 red are positive the 2 black are negative and the white is possibly data, possibly 1 red and 1 black are charge lines
Punteggio 1
2 Commenti:
Man, i didn't ask that, i asked why has 2, i know black is negative, red is positive.
So, why has two cable positive and two cable negative
I thank you for the cable white, i didn t know that.
For some reason has two cable red and two red,
Is it that has two different voltage?
da
as i previously said it could be to do with charging
da
Aggiungi la tua risposta
Severino Alcantara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 494
