Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
PS3 Phat 60gb unable to complete update/install firmware.
After bringing this PS3 back to life and fixing the fan, I was able to boot up the console where I began to update it. It was previously on 4.60 and was updating it to the latest firmware version; 4.82. It got to 99% and failed and kept retrying after failing at around 70%.
I've nearly searched everything and and anything and no luck in getting past this update stage. To the best of my knowledge, everything in the system is working and connected, including the bluray drive, spinning and all. Hard drive is also okay as I test this with another PS3, update process and everything.
Can an interrupted update affect the motherboard in any way? There must be something I'm missing.
One thing to note is when I press the eject button, I get a triple beep but the disk still ejects as normal. If I insert it back in, it takes it in as normal, spins, with the blue light visible. Could the triple beep be a symptom or is it the case that it's being ejected in safe mode?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you tried this….
http://www.tomshardware.com/forum/281383...
Punteggio 0
Aggiungi la tua risposta
Agent Morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 434
