Salta al contenuto principale
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
unABLE to wify connection
did everything to connect to wi-fy nothing unable and its brand new
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey Angel
If this is an Android based device the Wi-Fi setup should pretty straight forward. Open the Settings app on the tablets main screen, head to the network tab and select your network SSID.
If you are unable to connect to your network check your router to make sure that your device is not coming up as an intruder, or an unknown device. Sometimes routers block devices on the network because of security issues. If the device is recognized on your router verify the tablet has a strong signal strength.
If the problem still persists try to reset your tablets network settings, this will ensure that the tablet's network settings have been factory restored
Good Luck!
Punteggio 0
Aggiungi la tua risposta
angel perez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 261
