Failed Fusion Drive (both drives)
Both drives in my fusion drive failed. Have sent them off for data recovery, but am trying to save on the repair. I want to replace the fusion drives with only a single, larger-volume SSD. My hubs has experience building PCs, but we're not sure what exactly needs to be done here. We've been confusing ourselves looking over guides like How can I switch from FusionDrive to SSD-PCIe only? one.
Since both drives failed, do we still need to split them in Terminal? Can we even access Terminal if the computer currently has no drives installed?
If we leave the flash slot empty and only replace the HDD with an SSD, is there anything else we need to do or will the Mac read the SSD just fine and ignore the empty connection?
Questa è una buona domanda?
1 Commento
That was someone with a working system. As you claim yours is broken we need to be careful here if you want to save your data. And if you want to reconfigure your system then we can address that.
When I wrote that answer things have changed a bit. We now have a good source for the custom Apple blade SSD's and a good reference on what each system uses. Here's the reference: The Ultimate Guide to Apple’s Proprietary SSDs. Don't go crazy here I'm just putting it out to you to get a better idea what your system has.
da Dan
