Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
Which solid state hard drive to replcace
MacBook Pro 17” unibody 2011 needs new hard drive. Which solid state drive should I choose?
Update (07/30/2018)
Thanks! A follow up question: the Apple online info says that my early 2011 17” 2.2 ghz MacBook Pro has a max memory capacity of 8 gb total. Ifixit sells a memory max-out kit of 2 8 gb RAM chips for a total of 16 gb RAM for my machine. Which is correct?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I personally like the Samsung EVO drives, but any 2.5” SATA III (6.0 Gb/s) drive will work.
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 17" Unibody Hard Drive Replacement. IFIXIT does offer a kit with the needed drive and tools if you don’t have the tools.
Update (07/27/2018)
Here's the full details of your system: MacBook Pro 17" 2.2 GHz i7 (Early 2011)
What is confusing is Apple didn't go back and retest the system with the newer memory modules that came out just about 9 months later so thats why it lists 8 GB as the limit. My own 17" system has 16 GB without any problems!
Punteggio 1
1 Commento:
Thanks Dan, that’s what I was hoping. I ordered the 16 GB upgrade.
da
You can find the guides here: MacBook Pro 17" Unibody
Punteggio 0
Aggiungi la tua risposta
Peter Menderson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 86
