Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Why is screen green tinted and flickering?
A couple days ago my screen turned green after a few seconds of booting up. Here are pictures of the same image on my broken MBP and a functioning MBP.
Characteristics:
  • Some parts of screen flicker - different parts flicker depending on image (see end of album for video of textbox flickering on Wikipedia)
  • Screen changes shades of green over time (usual deepens)
  • Images appear normal on external monitor (via firebolt/hdmi)
  • The screen reverted to normal colors for an entire day yesterday, but is back to green today
Assessment from Apple genius bar appointment:
  • It's definitely the motherboard
  • The GPU looks like it's toast
  • ~$500
Assessment from computer repair shop:
  • It appears to be the display
  • ~$350
What I've tried:
Potential solutions
  • Replace display cable (LVDS)
  • Replace LCD
  • Replace entire display
  • Replace motherboard
  • Clean off some other component
I suspect Apple was wrong and this is not a motherboard issue because of normal external monitor behavior and the screen sometimes works.
Does anyone have any insights? Any other solutions? What should I try next?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
It is working on other screen in good condition so there may be problem with display connection or with display itself open the back panel of display check for a wire laminated with cloth or paper there may be a box uncover clean it then fix it.
Punteggio 1
2 Commenti:
What does "open the back panel of display" mean? The displays on MacBooks do not have panels.
da
The back cover of your mac display
da
To fix mine i updated the OS and installed the latest Adobe flash player. I have not had the issue on youtube or elsewhere since doing this.
Punteggio 1
2 Commenti:
Also if this doesnt fix the problem then you may want to reflow the graphics chip
if you use a hairdryer you can reheat the graphics chip on a not too hot temperature and it should work fine.
da
The screen colorings occur in non-video environments (e.g. just after bootup) so not sure how the Adobe flash player upgrade would help. Also what indicates that the graphics card is messed up?
da
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 6,467
