not sure i know enough about what was done.........
You can use a bootable linux CD to at least figure out if the hard drive is working correctly (assuming this is a brand new hard drive that has no MBR, etc...never been used before).
A bootable linux distro like knoppix or a free program like gparted could help find the drive, if found and you know how to use the tools in knoppix you can also help initialize/format the drive with HFS or another format........ and once formatted diskutility should handle any additional setup needed what ever that might be depending on what is done.
A great deal of this if not all of it can also be done via the command line options in a terminal shell in OSX for more advanced/powerfull features to help figure some of this out, however some experience would be required/recommended, if a mistake is made it could be costly. (wrong drive etc).
If this does not work check all connections, check if another hard drive (your old hard drive) works inside the optibay tray, if not then the optibay may be the problem......
All of the programs mentioned are free, i use linux, thats just me. Some others may have some other insights on resolving the issue or providing another suggestion.
I have not done a 2nd hard drive in a macbook yet, a EFI update or some kind of update might be needed that i am not aware of.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
