New hard drive not recognized by install disks
I just installed a new harddrive on my Imac G5 ran the apple hardware tests and mother board memory all fine. I checked your website attached all cables and neither the install disk or the hardware test can find the harddrive can it be a cable problem? If so where can I get new cables to attach the harddrive.
Any help is appreciated.
Questa è una buona domanda?
12 Commenti
Thats the thing, under disk utilities the disk can't be seen. When I run the dick utilities or the hardware test the disk is not there.
da Brad
OK so the hardrive stopped functioning, I thought it was a hardrive problem, put the harddrive in a case and ran it off my new imac runs fine. Bought a new harddrive anyways and formatted it today outside the broken imac and then installed still it does not recognize that it is attached. Turns out the old hardrive is fine, so it must be a cord or connection issue. The motherboard is fine according to the hardware test. Does that help at all? I am a bit lost with it as the install disks run fine but cannot see a hardrive attached.
da Brad
You need to replace the HD cable.
da Majesty
Any idea where to get one?
da Brad
There are 4 stores with them here. http://www.google.com/products/catalog?h...
da ABCellars
Mostra altri 7 commenti
