Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
623 Domande Visualizza tutte
MacBook Air 2015 Screwdrivers
Welcome,
I recently wanted to clean up my Air. I bought a Power 8800c screwdriver - star 1.2x50mm star. Unfortunately, I unscrewed a little and this screwdriver didn't fit.
I don't want to buy the same thing twice, so my question is - what more does a screwdriver need? Are P5 Pentalobe or T5 Torx or Phillips #00 the ones I have? Or maybe I still need the TR8 Torx to dismantle everything?
Thank you in advance for your reply.
Greetings
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @giorge ,
You will mostly need the P5 Pentalobe and the T5 Torx.
The display hinges will need the T8 Torx.
The trackpad will need a Phillips #00.
Punteggio 2
2 Commenti:
Hey, great thanks.
In this case I already have P5 Pentalobe (1.2 mm) and don't need P5 with other dimensions (e.g. 0.8 mm)?
da
That is correct. By the way, P5 should only come in 1.2 mm. 0.8 mm pentalobe would be a P2, and 1.5 mm would be a P6.
da
Aggiungi la tua risposta
Gorgio Antonio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 318
