Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Enclosure for iPod classic hard drive
Power source for iPod Photo 4th Gen (60gbs) died. I tried replacing battery but no joy.
Is there an enclosure or adapter o can use to transfer songs off the drive and then format as either a portable hard drive or as additional storage on a Mac Pro?
James C.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You can access this ZIF drive using a Universal Adapter:
Universal Drive Adapter
Immagine Turn your current hard drive into an external drive with this adapter.
Prodotto
$24.99
Punteggio 3
It may be the hard drive which has failed. If so your out of luck. You can still get some use out of it with this cheap fix
Punteggio 0
1 Commento:
Avais -
Thank you for your reply and attached solution. I was assured by the guy that diagnosed my iPod that the drive was fine, it is just the power module is defunct.
Regards,
James
da
This is exactly what you need: ZIF HDD caddy: https://amzn.to/42furqD
Punteggio 0
Aggiungi la tua risposta
James Coogan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 526
