Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
467 Domande Visualizza tutte
How much dismantling to replace battery?
Some people suggest that it is not necessary to remove the speakers, airport card, etc. to make a battery swap, suggesting that doing so is more likely to create a problem. Both iFixit and MacSales' tutorials have you disassemble several items, why? I would be interested to hear suggestions as to why one way or the other is better.
Update (07/24/2018)
Replacement battery was installed this past weekend, absolutely no issues. I went into it with Dan's advice in mind, but once I opened the case and saw exactly what was there I proceeded without removing the multitude of parts as per the instructions. Taking precautions to keep the glue remover away from all but the battery, I was surprised how easy it was to get the battery out. I used dental floss to gently saw back and forth, the first cell came out in less than ten seconds, I then loosened the other three small cells. When it came to the two large cells in the middle, I tried removing them with only the floss and no liquid remover, it seemed to work just as well without the liquid remover. I think the floss cut so well that the remover really wasn't necessary. Overall a very easy job and I felt much better not having removed the other stuff.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sadly you do need to pull the speakers to make room to get the solvent in and get the battery out. If you left them in you would get the solvent onto them damaging them!
It’s a required step.
Punteggio 1
2 Commenti:
Dan, thanks for the response. After looking at a couple of YouTube videos, I can see how tight things are in there and how it might be easy to damage adjacent components. I'm still concerned about the warnings in the tutorial about some of the connectors being quite delicate and folks mentioning problems getting everything lined up during reassembly. I'll be working on it this weekend, and will decide how to proceed once I get the case open and take a look.
da
I service one or two of these a day, Starting to put in more batteries as the older systems are now at their end. I haven't really had that hard a time. The glue is the biggest hurdle to over come both taking the battery out and putting a new one in.
da
Aggiungi la tua risposta
Charles Larkins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 97
