Kenmore Elite Refrigerator Problem 795.73157-610
How do I access the test mode using the reset switch on the motherboard, behind the fridge?
Questa è una buona domanda?
8-1-11 TEST Mode
1. The T est mode allows checking the PCB and the function of the product as well as finding out the defective part in case of
an error.
2. The test mode is operated by pressing two buttons on the Display panel.
3. While in the test mode, the function control button is not recognized, but the recognition tone (beep~) sounds.
4. After exiting the test mode, be sure to reset by unplugging and then plugging in the appliance.
5. If an error, such as a sensor failure, is detected while in the test mode, the test mode is cleared and the error code is
displayed.
6. While an error code is displayed, the test mode will not be activated.
Here is the service manual on your machine:
Water is coming from behind the panel in the ice machine area - dribbles down & freezing. Can not see where it’s coming from behind the panel the ice machine itself mounts to .
water feed tube has build up..take apart clean area on tube.. water is splashing up when the ice try fills, and getting behind the compartment walls.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 72
Tutti i Tempi: 8,066
1 Commento
My refrigerator 795.73157.610 the temperature of my fridge in the afternoon rises to 40 degrees and at night it drops 25 degrees or less. What could be the problem?
da a_maldonado29
