Salta al contenuto principale
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Can a broken mounting peg on an analog stick be repaired?
The right analog stick was non-functioning. Upon disassembly, I found the mounting peg for the stick to be broken in two. The base of the peg still appears to function, but can the two pieces be screwed and glued? I think a replacement would be a better option, but how? This controller was bought "modded" for rapid-fire for $60, so the replacement cost is higher than a regular wireless controller. Any ideas?
Questa è una buona domanda?
Punteggio 1
1 Commento
Depending on the thickness of the plastic you may be able to drill holes in either part and put a metal rod/pin etc use modelmakers glue to strengthen bond? I need to see it for myself to answer properly but this has worked in the past... You need a very fine drill bit..
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
With out seeing pictures I can't tell you about gluing it. But I believe this is the replacement part you are looking for here.
Punteggio 1
1 Commento:
Sounds like a cheap part and less hassle than my idea!
da
Aggiungi la tua risposta
marty sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,401
