Salta al contenuto principale
This Samsung Tablet was first released in May 2015 and can be identified by its 9.7 inch diagonal screen. The model number of the device is “SM - T550.”
44 Domande Visualizza tutte
(samsung t 555 ) Cant switch on tablet olso if battery is charged
I have a Samsung tab SM -555.The battery is still good but sometimes (a few times) I found it switched off and I dont know why (olso if I think the problem maybe can be the mini usb.One time after switching off the tab wont witch back on but afer "mooving something in the mini usb " I was able to power on again and use it (before I was able to power n the tablet only if the tab was connected at the charging cable). I think that it can be a false contact in the mini usb.Who can tel me the the order and functions of the various pins in the tab t555 mini usb?
Thank's
Claudia
ps: atm the tablet is working fine but maybe today,maybe tomorrow recharging it I will get back the same trouble :/
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check the charging port for debris and use something like a toothpick to clean it out. Shining a flashlight into the power will make it easier to see if it's physically damaged or blocked.
Punteggio 2
1 Commento:
@benjamen50 yes I have used a toothpick + can of compressed air and olso a spray clean contacts and after using a toothpick I was able to sorti it put (by the way are three days I use tha tab without any problem so I think s clean now.I neade to know witch pin is the one for the charge (or maybe is not a pin).Have u got any tip?
Thank's
Claudia
da
Aggiungi la tua risposta
claudiasandersbis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 65
