Salta al contenuto principale
Pixel XL (Modello Numero: G-2PW2100), primo smartphone Android di Google, è stato rilasciato il 20 Ottobre 2016. Ha un display AMOLED da 5,5 pollici, batteria da 3450 mAh, e due configurazioni di memoria ,da 32 o 128 GB.
71 Domande Visualizza tutte
Can the finger print scanner be painted or have a wrap applied to it?
II'd like to change the color of my Pixel XL fingerprint Scanner. I've seen durability test videos where they highly scratch a scanner and it still works. I've also seen cases with a thin plastic film over the scanner that still allows it to function.
I'd like to ideally remove the paint currently on the fingerprint scanner and repaint. Alternatively, I'd settle to have a wrap applied to it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Seeing as slick wraps provides skins that also stick to the fingerprint scanner i'd say that it still works with a sticker on there, i'm not too sure about paint seeing as that is a lot thicker than a sticker
Just a thought..
Here is the link to my example: https://www.slickwraps.com/galactic-seri...
Punteggio 1
1 Commento:
Thanks so much, that totally makes sense. they're so cheap, I might just buy one and try and paint it to see what happens
da
Aggiungi la tua risposta
Helpful sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,964
