Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
Why is my display not working?
About six months ago, I splilled water on my MacBook. I took out the logic board and cleaned it. Everything worked properly. I decided to clean the logic board again when I installed a new trackpad cable a few days ago. Upon reinstalling, the display doesn't work. I am able to use the computer fine with an external monitor. I can't figure out if it's a problem with the display socket on the logic board or if I should purchase a new replacement display.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It's impossible to answer your question without testing the logic board, or trying installing a known good screen. Given the history of your Mac I'd be more inclined to think about a logic board failure. Lvds connector and lcd enable circuit would be the first to check in my opinion.
Punteggio 1
Take a flashlight and shine it through the Apple Logo. Are you able to see your desktop icon’s? If you do then your issue is within the backlight circuit. It could be as simple as a burnt fuse link or needing a new driver chip.
Punteggio 0
Aggiungi la tua risposta
Sam Quinn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 107
