Salta al contenuto principale
Why does my CRT have a thick black line on the top?
I have an Emerson ECR1350 from 1990, and it has been stored in the garage of my beach house for a few years now. I pulled it out and it worked, except 8th of the TV is just black with some horizontal white lines on the bottom of the black part
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The vertical circuit is in need of repair. The vertical IC may be the problem or a couple of capacitors in the vertical circuit need to be replaced or both. In any case, the parts cost for this should be around $25 along with the local repair labor rate. This is a common problem and anyone that has done CRT based TV repair should have the parts in stock.
Dan
Punteggio 1
Aggiungi la tua risposta
BigNerdBird sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 502
