Salta al contenuto principale
Model number: IMW477-DR. This bluetooth speaker features an IP67 rated waterproof design with an on-board microphone. Available in black, blue, gray, green, and red.
How to replace usb charge port. Where are these parts to buy
How do I replace the USB charge port and where do you find these parts in these pictures
Questa è una buona domanda?
Punteggio 3
8 Commenti
Mine is broken currently and soldering the USB charge port back on looks like a pretty difficult venture.
da
Just took mine apart and the inside of the charging port fell out, immediately. Placed it back in and it's charging now...I know I'll have to solder, or at least glue, but doesn't look to hard at all. Just rip it open and get busy
da
la lia ya no sirve el puerto de carga .se aflojo y el cargador ya no queda bien y desde entonces deje de usarla. Pero quiero repararla ,mas no se si se pueda ,reparar
da
The speaker don’t charge
=== Update (06/27/2020) ===
The speaker model IMW575 don’t charge
da
imw581 charging port for my altec
da
Mostra altri 3 commenti
Aggiungi un commento
2 Risposte
Risposta Più Utile
@pinkxster looks like it may be a fairly standard micro USB charging port. Open it up using these guides Altec Lansing Mini Lifejacket 2 . Check if the port is just loose on the board and may be it can be soldered back in position. Replacement ports are available at places like this or on here. Check videos like this and this one to see what is involved with that.
Punteggio 1
1 Commento:
Puerto de carga averiado
da
Altec Lansing charging port.lifejacket jolt model:IMW581L.
Punteggio 0
Aggiungi la tua risposta
Alton Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 58
Tutti i Tempi: 10,621
