What does the light in the dash of the circle that has a line through
What does the light in the Dash it has a circle with a line through it and a key that is lit up what does the symbol mean
Questa è una buona domanda?
This has to do with the car security mode. you may have a problem with the chip in your key .The system is called Sentry Key Immobilizer Module (SKIM). (Also called SKIS) Your not going to be able to pull the codes yourself because the codes are not stored in the PCM. But in the SKIM Module itself. So a normal OBDII reader wont read the codes here
http://wjjeeps.com/02gauge2.jpg Note #12 in diagram
Hope this helps
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,710
