Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
597 Domande Visualizza tutte
MacBook Pro 15" suddenly shutdown, wont turn back on.
Hi all, yesterday i was working with my laptop while it was charging. i get up to move and unplug the power and a couple seconds later the entire machine suddenly dies.
for the last couple weeks the battery indicator has been saying off and on that it may need servicing so that may have something to do with it? i plug it back into power straight away and the light comes on. the battery indicator on the side was on 3 dots with the 4th flashing. left it charging for a while to try again later. the battery is now full and still has no life but notably it was a little warm. no where near hot. just like warm as if it had been running.
i have read through multiple other forums and tried to find a fix to no avail!. the only sign of life ive had was an SMC reset. all that happened was the light on the charger went green for a couple seconds then orange again with no other signs of life....
im really stumped on what the issue is so any ideas would be greatly appreciated!
thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Plugging in magsafe after removing battery connector from the board should allow the Mac to start if it's only a battery issue. Mac should boot on its own without a need to push power button. If that's the case, probably a battery replacement will solve the problem.
Punteggio 3
2 Commenti:
[image|1494711] Even Like this cant even get the fans to spin up they flicker then stop same as when its assembled completely
da
Not much left to try..it's most probably a logic board issue, would need deeper testing skills and tools and component level repair. Or a replacement logic board..
da
Punteggio 0
Aggiungi la tua risposta
Luke P sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 364
