Hello,
I Have the same problem to you. I fix with the next stapes:
The first you need to know is for example, if one headphone is no working (speaker left for example) or wire, the beats doont turn on.
In my case one wire is not establishing conection, (you can check with a tester).
You need to do 3 important stapes:
- The first is connect beats to usb, and check the windows reconize your headphones.
- Check battery status
- Finally with connect usb on pc, press 10 seconds power button, you see your beats disconected to pc. (If not, you have a power button problem)
If this stapes are working good, check your music with and auxiliar cable, and see are listening left and right speaker.
In my Beats on Left case, one wire is not doing your funciont, like this:
This PINS are very sensible and is posible is broken, check the 3 PINS, and normally this is your solution.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
9 Commenti
I'm having the same issue.
My Beats Solo3 wireless headset will not turn on.
The firmware is up to date, and they are being recognized when I go to your.beatsbydre.com website, and the battery is at 100% per the website.
The 5 white led lights illuminate when its plugged in, butif I unplug it from the charging source, the led lights disappear gradually, but the headset will not turn on when I press the power button. Even after trying all reset solutions (hold down Power+Mute for 10 seconds, 2 minutes, etc) while being plugged in and/or unplugged. Still nothing. No lights. No power. Please help :((
da MyBeatsSolo3
did you resolve this?
da Matt Corliss
The only way to relsolve this is have a person at Apple send it in for repair and they reprogram it or they send u a new one if you have warrenty, if you don’t have warrenty than I don’t know if you can still send it in but costs a lot of money to send it in without complete coverage
da Ryan Schreiber
Having the some problem with mine.
Apple tried to charge me $129 to do this service without the warranty.
My warranty literally expired a month after this happened to mine...
da dylanjeter123456789
Same situation, but after some ~six months (we could not send it to repair back in march due to the lockdown) I tried to recharge the headphones and they work as if nothing had happened before. Apparently the emptied battery somehow reset the headphones.
da Jan Martinek
Mostra altri 4 commenti
