Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Is there anyway to get data back from the phone before it’s set up ane
I know I’ve asked this question already and it’s been answered many times however I haven’t set up my iPhone 5 as a new phone just yet and I’m wondering is there anyway of getting my data back before I lost it I had 3 apps and 21k photos on the device I’d really appreciate it if there was a way to get the data back
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Stinger Solar  just like any other time (this is #5) you’ve asked the same question. If you do not have a manual or icloud backup, your images are gone. There are no magic tricks or magic software that can help you with this. There is nothing else you can do about it.
Punteggio 1
It really depends on how you had iCloud set up on your previous iPhone(s) or other iThingies. If you have your iPhone set up to back up your photos as well as system critical data to the cloud, it should be simple to get your original stuff working on the new iDevice. At some point in the initial setup on the new device, you are given the option of authenticating to your Apple ID (you need to be on either a wireless (preferred) or cellular data connection ). If your Apple ID is accepted, you are given the option to restore your previous iCloud data to your new device. If you select yes, it will likely take quite a while - depending on how much stuff is being restored - but things should work quite well once the process completes. This is actually one of the best things about hanging out in the Apple "walled garden". As long as you stick with Apple devices, migration is simple.
Punteggio 0
Aggiungi la tua risposta
Stinger Solar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 52
