Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
561 Domande Visualizza tutte
Capacitor knocked off from logic board
Hello guys,
I was doing a battery replacement on my mid-2012 retina MacBook Pro and I was a tad confuddled by how the battery connector removed.
On my third attempt, I managed to knock a fuse (from what I've Googled) off the logic board that was near the connector.
I tried Googling and using schematics to find out what that fuse does and the current / resistance measurement so I can replace the fuse.
I've included a link to which fuse I need knowledge on
Fuse near battery connector
I'd appreciate any help given.
Edit I: It's a capacitor, not a fuse. My Googling sucks (changed title).
Edit II: Additional photos attached of actual motherboard. The capacitor has a light brown strip on it.
Questa è una buona domanda?
Punteggio 0
3 Commenti
What's the logic board number ? It should be marked on the board..reading something like 820-xxxxx
da
I have to double check, but it's manufacture part #: 820-3332-A. This is a 1st generation base 15" rMBP with no upgraded options.
da
I've double checked and that's the correct logic board number.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That's a not a fuse, it's a capacitor, C6960
a 1UF cap
10%
25V
X5R
in a 603-1 package
Punteggio 1
4 Commenti:
Whoops, sorry about that. I was trying to Googling what it was. Thank you for the information. Would you know what that capacitor does, by any chance?
da
@kevkev it is part of PPVBAT_G3H_CONN circuitry which is your PBus supply & battery charger circuitry.
da
@kevkev I'm not an engineer, don't know what's exactly its purpose but being so small I'd presume is there for smoothing purposes.
da
Awesome. Thanks for the information and your time.
da
Aggiungi la tua risposta
Kev K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 201
