Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
No network since I changed my display
Since I changed my broken glass/display on my Iphone4 using ifixit repair guide.
My Iphone is searching networks for hours, sometimes it find my prvider (vodafone germany) and I get just one bar.
If I move the phone, it instandly loses the connection.
The Phone is free/unlocked and the sim card works fine in every other phone/Iphone I tried!!
Also, I had a small plastic/rubber thing left over after I finished changing the display, couldn´t found this little part on any of the Iphone4 pics over here
any advise??
Thanxs, Dan
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like an antenna connector issue. Take it apart and see if the connector is loose or not plugged in. Try doing a hard reset as well. If it is plugged in, very carefully and gently wiggle it. It might just make the difference. Best of luck.
Punteggio 3
Aggiungi la tua risposta
Daniel Grosse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,184
