Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Damaged Sim card Reader
Hello,
One of the screws got loose and got stuck in the sim card reader slot. I was able to move it out with a tweezer but in the process it moved around in there too much and must've done some damage because now the phone won't read the sim card at all. Do you think the sim card reader needs to be replaced or are the pins bent? Is it fixable?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If you can see the pins, maybe you can bend them back into place. It's hard to know without seeing a picture. If all else fails, I'd replace the sim card reader. Unless you have microsoldering experience, I wouldnt try it. There are a lot of great companies that offer these services.
Punteggio 0
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 393
