Salta al contenuto principale
The Kenmore Direct Drive is a washing machine by Kenmore.
Spin basket (drum) does turn in spin cycle
I have a Kenmore 400 (model #: 11029422801) and the washer goes through the wash cycle without problem until it hits the spin cycle. During the rinse cycle, it appeared that the agitator and drum spun in tandem when the water was draining. But in the spin cycle, only the agitator spun and not the drum. I've been advised that this may point to a faulty timer, but a bad clutch seems to make sense too.
I've already replaced the lid switch and that did nothing to address the problem.
Could you advise? I'm trying to decide which repair would solve this issue.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Take the agitator out and look to see if the bottom of the spin basket is broken out. If so you will have to replace the spin basket. A lot of these washers have a lifetime parts warranty on the spin basket. If the spin basket isn’t broken I believe the transmission is bad or the hub nut is loose. To check the hub nut you will have to remove the agitator coupling.
Punteggio 2
Aggiungi la tua risposta
Mark J sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 679
