Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
How can I fix my wireless connectivity
I have a 2.1ghz Macbook, model number 1181.
The wireless connection is extremely flaky with this computer. The wireless connection with fine with other devices, including 2 iPod Touches, a mac mini, an old G4, and various PC laptops.
The Macbook's problem is that wireless connection is not steady. Upon turning it on or waking it up, the connection is fine for about a minute, the Airport display shows full strength in the menu. Then everything just drops out. The Airport drops in strength, showing only one or two bars. Connecting to anything via the internet becomes impossible, the web browser displays messages that say it's not connect to the internet. If I click repeatedly on the Airport display in a rapid fashion, that seems to improve connectivity as long as I keep clicking.
After an indeterminate amount of time, somewhere between 15 minutes and half and hour, the connection steadies is generally more consistent. If the computer is turned off, put to sleep or switched to another user, the problem begins all over again.
'''Notes on things I've tried to fix this:
'''The Macbook is running the latest addition of 10.5.
This happens in Firefox, Safari, Opera and Camini.
I've tried deleting all known networks and starting from scratch with just the home network.
I've tried using different channels on the Wireless router
Interference robustness is on.
I've tried placing the Macbook closing to the router, but that doesn't help.
If the Macbook is plugged into the LAN via Ethernet, the connection is strong and steady.
This occurs with three different routers: An Airport Extreme, Airport Express and Linksys router.
Anyone have any suggestions how this can be fixed?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It sounds like you need to first check your connections to the airport card and/or replace the card. If you give the last three letters of your serial number, we can direct you to the correct part and guide to replace it. The number can be found in your battery compartment.
UPDATE -
Check your connections here: MacBook Core 2 Duo AirPort Card Replacement
Here's the airport part number: 661-4460
Punteggio 4
3 Commenti:
Apologies, at work now, so don't have access to it. It is model number A1181, that I do know.
da
OPO are the letters.
da
Apple MacBook "Core 2 Duo" 2.1 13" (White-08) Specs
Identifiers: Early 2008 - MB402LL/A* - MacBook4,1 - A1181 - 2242
da
I've noticed that Airport extreme cards run quite hot while on (mine averaged about 140F), perhaps it is over heating?
Punteggio 0
2 Commenti:
But it wouldn't be overheating if the problem occurs while starting up cold, you know?
da
In theory, you're right. In practice, who knows? Mine would heat up very quickly (about 10 minutes) which just adds to the high heat my imac runs at already.... I'd check all the connections, run a diagnostic on it, and as a last resort buy a new one.
da
Aggiungi la tua risposta
Josh Mitchell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 743
