Sony Dvd player power supply problem
my dvd player isn't turning on..so I open it and checked in power supply for output voltage and I didn't find any voltage in output segments.its build on tny176pn ic.
I started with fuse which is ok..than for any open diodes and found none..I checked the opticoupler for little voltage which I expected and there's none.
I measure the tny176pn ic's en pin and also no voltage.
so what should I go for??
thank you!!
Questa è una buona domanda?
Help me out here, the cable running from the battery (power supply whatever you want to call it) before going into anything else does it plug into a board? If so chances are that board is fried.
da Timothy McEvoy
Hi @rony007
I would like to check more info from you, which country did you use at?
and what voltage? 110V or 230V?
I noticed that on the teardown, the board seems to be a 110V,
thus need to confirm your powerboard if it is a 110V or 230V.
da Augustine
its 220v in our country...it was working fine!
da rony_hassan
@rony007
where did you " found 320v." on your power board? What else have you checked?
da oldturkey03
on the primary section of transformer its getting 320v...I checked tny176np..I checked directly to the transformers secondary section but no voltage...I checked transformer secondary section winding ok!what would be the cause of no output voltage?
da rony_hassan
Mostra altri 2 commenti
