Salta al contenuto principale
Informazioni e guide di riparazione per la versione aggiornata del Retina MacBook del 2015, rilasciata all'inizio del 2016. Modello A1534 / EMC 2991
No output devices found
Hello All,
I recently installed a new display assembly on the macbook and had some issues. I finally got the display working when i realized that the audio cable was in backwards pins side up instead of down (dumb mistake). When i put everything back together I was worried that the sound may not work. sure enough its not working. not internal speakers are seen by the computer. the error is no output devices found. I reset the PRAM. and even reinstalled OSX. I have checked all my internal connections to the logic board. i ran a hardware diagnostic and its not seeing any issues. I am worried that the audio board and the cable might be fried... any ideas would be awesome.
PS. plugged in headphones and no go.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
I know this question is old but you most likely tore the audio board flex cable when you disassembled the machine
Punteggio 0
Aggiungi la tua risposta
Yelitza rodriguez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 15
Tutti i Tempi: 714
