Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
How to quit the installer
I have got notification for soft wear update and I have allowed to update. After that my iMac is not opening. Message is showing as follows "macOS could not be installed on your computer. Quit the installer to restart your computer and try again." Now how can I quite the installers?
Questa è una buona domanda?
Punteggio 0
1 Commento
what OS X are you running? Which update does the APP store say it is?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You should have the possibility to close it from the menu bar but since something went probably bad during install it might be the menubar is not there ? If so you don't have any other alternative left than force shutdown with power button. Hopefully it will boot correctly otherwise you'll have to reinstall the OS.
Punteggio 2
1 Commento:
How can I get OS, it poss lie to download from Apple Store?
da
Aggiungi la tua risposta
shamaun1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 142
