Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Rear Camera black/purple lines
iPhone 6 came in with purple vertical lines when choosing the rear cam. Changed it with spare, went all black afterwards.
Ordered a new rear camera part from Ifixit, Same problem! Black!
Front camera works fine, and by hitting the Change camera icon several times I get the purple artifact on the rear cam.
Now I’m thinking this is a board issue, so before I start with the micro tweezers I thought I should ask if someone in the community has encountered this before?
I have checked if the screws holding the LCD connector cover have been put in the wrong nut standoff and penetrated the motherboard, but no luck there!
Cheers!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi,
After doing som diagnistic I found that the problem was related to PP2V85_RCAM_VDD. When I got the red lines this voltage was alternating. When the cam was black this voltage was zero.
I changed the LDO U2301 without any change. So my guess is there is something wrong with the enable signal to the LDO from the A6. This is a straight trace without any vias, so monetoring this signal is difficult.
This phone was not worth any more fault finding, so I have not got a 100% answer for the problem, but the 2.8 voltage was not present when the rcam was black so this signal path is my best guess;)
Punteggio 1
not encountered with this problem yet, good luck bro, please share with us how you nailed it :)
Punteggio 0
Hi! There are black likes in the corner of my camera and I don’t know why
Punteggio 0
1 Commento:
Have you replaced the camera? Or did this occur suddenly? I understand this is an iPhone 6 since you posted under this thread?
da
Aggiungi la tua risposta
Roger Høiås sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,568
