Salta al contenuto principale
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
ipad touch does it work?
i did replaced screen on ipad pro 12.9 a 1652 but id touch didnt work i think im going to buy iPad Pro 12.9" LCD Screen and Digitizer Assembly from here do you think its can work on my ipad espcially id touch plz help
Questa è una buona domanda?
Punteggio 0
3 Commenti:
tnx brain for amsweing i tried screen but didnt work but it wasnt with ic chip so do u think if i get this full screen with ic chip that would work?
da
Can you upload a pic of the part you currently tried? Are you asking if you get another part with the touch id button would it work? If so, the answer is no. The touch id button (touch ic home button etc) only works with the original motherboard, so buying another wont work.
da
yes that was my question...i see ...so what you advice me to do and thanks again
da
Aggiungi un commento
1 Risposta
Have you installed the screen all the way? Also, does the home button work just not the touch id function?
More than likely you may have damaged the home button flex when transferring it over.
You can try another assembly, but I'm not confident that will fix the issue.
I would make sure the home button cable is installed all the way. Transfer it back to the broken screen again, if it's still useable.
Punteggio 0
Aggiungi la tua risposta
Faris Sh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 157
