Tire Pressure light is on, even though tires have air.
Out of my manual, the signal is on when i turn the car on, and it stays on meaning there is a malfunction in the system, no message pops up only the low pressure indicator.
Tires are as follow: 36 - 35.5 || 36 - 25
Tire recommended: 34 psi || Front + rear.
*Not sure if having a higher PSI will trigger a warning or not
- Not sure if the car is checking the pressure in my spare tire or not
- I DO NOT have a reset button in my glove box, keep in mind i have a 07 VW jetta.
- i believe the person i bought my car from changed the tires to slightly larger ones, so i don't know if i need more or less PSI
so
*Does my 07 jetta check the spare?
- is there a reset button some where on the older ( 07 ) models i don't know about?
- i will lower the psi to the recommended 34 to see if that helps, and check my spare and will update this post afterwards
Questa è una buona domanda?
Punteggio
0
