Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
earpiece has sound distortion
Has anyone seen this problem before...
iPhone 6 plus has distorted sound through earpiece only (loud speaker and headphones have good clear sound).
I changed earpiece speaker and also flex cable but no improvement - sound still distorted.
The phone doesn't appear to have been opened before and hasnt suffered water damage.
I would have thought it was the audio ic if sound was distorted on loudspeaker and earphones too, but this is not the case.
Confused!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
How does it sound distorted? Like muffled or more of a popping noise? If it's muffled/quiet then it could be the earmesh. Also check if there are any rips on the front flex cable
Punteggio 1
3 Commenti:
It is both quiet and fuzzy - not muffled or popping. kind of like the distortion if you put too much power through an amp (just not so loud!)
da
I guess try to remove the earmesh (or clean it) and test that out. A ripped cable doesn't cause distortion in the sound and if you've already replaced the earpiece then that is probably not the problem.
da
Thanks very much for your help, you were spot on about the earmesh. I could understand it making it quieter but never thought the sound would distort from a clogged up earmesh!
anyway thanks again
da
Aggiungi la tua risposta
ayejay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 7,200
