Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
Battery not holding a charge
Hi!
I purchased last week the battery replacement kit from iFix for my Mid 2012 MBP. Swap went smooth, just like the article explains it. However, I've noticed that after the battery is fully charged. it doesn't hold the charge. I left the laptop with about 80% last night, shut it off, when I turned it back on this morning, it immediately dropped to 6%.
Is there a reset or a software step I have to take after the new battery is installed? Thank you for your help in advance!
Rafa
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Risposta Più Utile
I’d download, install run and post your finding using Coconut Battery so we have a better idea of what is happening
https://www.coconut-flavour.com/coconutb...
Punteggio 2
You can try a SMC reset. https://support.apple.com/en-us/ht201295
Punteggio 1
Dud battery. Was it doing the same thing prior? If not, get this battery swapped. Dud batteries happen.
Punteggio 1
Aggiungi la tua risposta
Rafael Otero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 415
