Salta al contenuto principale
MacBook Pro con display Retina da 13" fabbricati a partire dal 2012.
4681 Domande Visualizza tutte
Wi-Fi icon won´t show up
I have a MacBook Pro A1502, the wifi icon dosen´t show up, I´ve changed the wifi card and still the same. the Bluetooth is also damage. When I change the card for another one the bluetooth appear, but the Wi-Fi still disable, I can´t start nor create the service throught the terminal, it says that there is no Wi-Fi device. HELP PLEASE!!!
I also try to enable the wifi network service in the terminal but the listallnetworkservices command doesn´t show any wifi interface
Questa è una buona domanda?
Punteggio 0
1 Commento
The A1502 covers quite a few different models! Can you pick yours from this listing: A1502 systems
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I’m suspecting the I/O cable needs to be replaced. Here’s the IFIXIT guide for the 2014 model: MacBook Pro 13" Retina Display Mid 2014 I/O Board Replacement and here’s the needed part: MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable but without knowing your exact system I’m just guessing here.
Immagine MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable
Prodotto
$9.99
Punteggio 1
Aggiungi la tua risposta
Luis Anniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 137
