Broken Glass, LCD intact and not adhered to digitizer.
Somehow my iPhone 4 digitizer cracked and was not adhered to the LCD. Can I replace just the digitizer?
Here's a link to a photo of it on imgur
Thanks.
Questa è una buona domanda?
Thanks.
Yeah this is easily solvable, usually they are fused together so your phone must be a refurbished one.
Just buy an iPhone 4 digitizer off eBay for around £12. Then use the ifixit guide to replace it.
It's alot easier than people make out.
I ordered a digitizer on eBay on the cheap, replaced it myself. It was fine at first, and was fully functional in the beginning-but then it turned south. Due to the fact that the LCD and digitzer weren't adhered to each-other, there was a small space, probably about 2 or less cm. This resulted in the digitizer being raised a tad from the lcd, which was annoying because when you applied pressure, it was depressed into the lcd. Luckily, I was able to get it replaced by Apple. So while it worked temporarily, I would not recommend this in the long run.
I am not 100% sure looking at your photo but.....
It looks like your outer glass is broken and not your digitizer.
If i am right, these can be purchased very cheap on ebay.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,552
1 Commento
Update:
da dman244
