回答としては時間的に凄く遅いのですがUSB-C端子の接触不良なのか、USB-Cコントローラチップ不良なのか,TB3は動作するのかと言う、
その辺りの切り分けは出来ていらっしゃいますか?
私のMacBookは充電以外にUSB-Cを使わなかったらUSB-Cとして認識しないと言う事案が発生しまして、
これは接触不良だなと思いTB3ケーブルを抜き差し50回ほどで回復しましたが、念のため
あほぷるジャパンの保証で持ち込み修理実施しました。分解点検でサービスプロバイダは小遣い稼ぎがしたかったようで端子のみ交換されたようですが、事実上交換は不要と考えます。私も2017/27@2と2017/21を使っていますがこいつらの端子にはケーブルを挿しっぱなしにして前に出しています。
切り分け出来ていないようでしたら一度試してみて下さい。
なお、2017CTOを購入し、現状のUSB-C不調の物をヤフオクで「訳あり特価 USB-C不調のためジャンク NCNR」
これで飛びつく方々が山のようにいらっしゃるかと思います。
The answer is that it is very slow in terms of time, but is it a bad contact of the USB-C terminal, a bad USB-C controller chip, or does TB3 work?
Have you been able to separate the area?
There was a case that my MacBook would not be recognized as USB-C unless I used USB-C for anything other than charging.
I thought this was a bad contact and recovered by plugging and unplugging the TB3 cable about 50 times, but just in case
We carried out repairs brought in under the warranty of Ahopuru Japan. In the overhaul, the service provider seemed to want to earn pocket money and only the terminals were replaced, but I think that replacement is virtually unnecessary. I also use 2017/27 @ 2 and 2017/21, but I leave the cable plugged into these terminals and put it out in front.
If you can't separate it, please try it once.
In addition, I purchased 2017 CTO and bought the current USB-C malfunctioning thing with Yahoo Auction "Junk NCNR due to special price USB-C malfunction in translation"
I think that there are a lot of people who jump with this.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
