Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 not charging
hi
i have an iphone 6 its not charging, ihave checked u1401 and found there caps under it C1412,C1416,C1480 is shorting i have removed those but after i probe them again still its shorting on their line.
but now charging voltage from battery terminal is variable like 0-4v changing per second previosly its like dead when usb plugged
what can be happend i am suspicious that i am damaged u1401 chip. or where should i check other then those 3 caps. btw vcc main of phone is not shorted. only vbat is shorted
(i havent replaced new caps after removal)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
C1412/C1416/C1480 is on the PP_BATT_VCC line. However, there are a lot more caps on that line than just those three. You will have to search through the schematic to find all of them and you will want to test them all. Of course, the problem could also be within Tigris itself so you'll have to decide if you remove that first or last.
Punteggio 1
2 Commenti:
thanks for the answer,, battery line still shorting.. is that an effect on these voltage reset thing i was pulled . out randomly 3 caps .should i put them back or how can i find the error component without pulling them out i mean testing them on the board is that possible
da
can you give me your contact no or watsap
da
Aggiungi la tua risposta
tatlisub sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 155
