Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
425 Domande Visualizza tutte
Will not charge or turn on. Buzzes when charging.
My phone was fine. I ran the battery all the way down. Put it on the charger and checked it. It wasn't charging so I plugged it into another outlet. It started buzzing every couple of seconds. Tried another charger and the same thing happened. When I tried to power up, it had a picture of a plug and outlet. Which wouldn't be odd, accept it's never done that before. I don't know enough about it to have comfortably taken it apart.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I've never heard of a plug and outlet image sign before.
I've only ever seen the battery logo / percentage with charging bolt and green .
Sounds like either battery has gone faulty or needs to be charged up again as it has gone dead flat.
I actually had to disassemble the phone to the battery and externally charge it on two Samsung Galaxy S6 edge plus that had the same issue.
You are probably going to have to take it to a phone reputable repair shop to get it fixed / diagnosed hardware wise.
Punteggio 6
2 Commenti:
Thank you so much for your help. I've never seen the plug and outlet symbol either. I will take it in.
da
I have this problem too. What did you do to fix it?
da
Aggiungi la tua risposta
Penny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,352
