Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
earspeaker dosent work (i think I shorted it out)
i took my iphone apart to replace a faulty vibrator motor... after i replaced it i was reassembling it and when i wanted to connect the screen with the nr. 3 connector i accidentally touched the pins with a screwdriver, and i saw a small spark ... i noticed a very faint smell of (burning electronics)... i managed to re assemble the phone.. i turned it on, seemed to work fine.. i tested the touch sensor ,home button, proximity sensor, ambient light sensor, and they all worked but when i got to testing the earphone it didn't work...
i think i shorted something out... but i don`t know if it is the speaker itself or something on the motherboard...
if i order a replacement earspeaker will it resolve my problem???
any ideas?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sparks are not a good thing during a repair. If not the earspeaker, then Flex Cable #3 would be the next part to try. If that is not it, then Logic Board.
The most fragile part in this complex of parts is the Flex Cable #3, then the #3 connector piece, then the Speaker itself. But with sparks flying who knows.
Good luck,
Brad
Punteggio 1
9 Commenti:
The ear speaker is just a simple magnet, there isnt anything to "short" out on that, I would check the #3 ribbon if you're having ear speaker issues. Does the proximity sensor work?
da
what is the purpose of the very very fine copper wire wound round the speaker then? I would have thought that this could easily be damaged by power surge..
da
The speaker is like a magnet. Sound is induced by electrical current to move the membrane, but there isnt anything to actually "short." Its like when you wrap a copper wire around a screwdriver and connect the leads to a battery. You basically create an electromagnet.
da
so looks like you are in agreement with what Brad stated..
da
If a current surge passed through a hair fine wire it wouldn't damage it? Prevent the electromagnet from receiving power?
da
Mostra altri 4 commenti
The speaker isn't damaged. It is the #3 ribbon cable. You can get one off ebay for $7 or less and make sure you search for US only. This cable is a little tricky to install because the metal clip that hold it in is quite sturdy. Bending it a little bit is okay, but make sure you bend it back. That is really the only thing I can think of that got damaged. I highly doubt it is your logic board. But I guess there is a small chance it could be. Hope that helps!
Punteggio 0
Aggiungi la tua risposta
Ignat Robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,496
