Salta al contenuto principale
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Domande Visualizza tutte
Power LED comes on, but turns off after 15 secs.
I have a friend's PSP3001 that will not turn on. The battery is charged, and when I turn it on the power LED turns green for 15 seconds and then turns off. The screen doesn't show any signs of powering up, and I cannot hear any sounds from the speaker or the headphone jack. He swears he wasn't trying to change/update the firmware, just hadn't played it in a while and could not get it to turn back on.
Does this sound like bad connections or is it bricked? I was hoping to have some clues before opening it up.
Thank you in advance.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It honestly sounds like its bricked. If it is a bad connection, then you should be able to see it when you open it up. Not having sound, video, or even a boot up (assuming its not bricked) suggests a loose ribbon cable or bad fuse. Let us know what you find when you open it up. :)
Punteggio 0
4 Commenti:
I opened it up slowly, checking for any signs of water or debris damage, but it was clean. I checked the connections before I disconnected anything and they were all tight. I metered the fuses that I found and they were good. I am guessing it was bricked. He isn't the type to jailbreak his own things, so I don't know what would have happened, but now he has spare parts for his new PSP; he was able to get the same model.
Thank you for your help.
da
You can also brick it by interrupting a normal firmware update; i.e. disconnecting power while installing. At least you got something nice out of it.
da
I have exactly the same problem only difference is that I get the intro sound the screen flashes for 1 second but then shuts off. I have to mention that I cant turn it on by the power button. This is weird I just plug the power in and then quickly unplug it and it turns on which in turn runs off the battery but shuts off after 5-6 seconds. What can I do about it ?
da
@letty...you may get better answers if you ask your own question. Give as much detail as possible. Right now your question is listed as an answer to a very old question.....use the "ask a question" button below the device picture.
da
Aggiungi la tua risposta
bugman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 7,965
