Salta al contenuto principale
The Motorola G5s Plus can be identified by its model number: XT1804 (varies based on country). It is an updated version of the 5th generation of Motorola’s Moto G series. Some distinguishing features of this device are its metal unibody design, improved front and rear cameras, and bigger battery.
17 Domande Visualizza tutte
Usb charger smells burnt after use with my phone
I bought and started using my g5s plus 12 days ago, today i notuced a soft bu,zing sound coming from my turbo power charger(included in the box) and i looked into it. While doing this i found my usb port( on the power brick) and the usb connecter( that goes in the power brick) smelt burnt.
I tried another charger thay has been used with a moto e4 before and that smells a little bit burnt too now.
Turbopower is 3 amperes
Does this have something to do with my phone or is this normal?
Should i get my phone replaced(if so is that free or is this noy covered by warrabty)?
Questa è una buona domanda?
Punteggio 0
1 Commento
Also, is it stilk safe to charge my phone now?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Get the phone replaced. This should be covered under warranty. It was caused probably by the fast charger
/ cable provided by your phone or the charging circuit not working properly on your phone. I would also ask for the wall charger and cable to be replaced just in case.
Punteggio 3
Aggiungi la tua risposta
Thomas van de Weerd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,003
