Salta al contenuto principale
The RCA Voyager Pro tablet is a perfect entry into a world of wonder and entertainment. Running on Android’s Lollipop, the Voyager Pro is sure to excite and entertain.
How do I get my tablet to run faster
how do i get my tablet to run faster
Questa è una buona domanda?
Punteggio 5
2 Commenti
It slowed down? Or it's like that from the factory?
da
I now have this problem too. What can I do to fix this problem?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Go to Settings, storage, then clean cache.. depending on the tablet, The cache may be located somewhere else in settings. You can also down load a cleaner/optimization (optimizer) app to clean and boost your tablet.. you may have one installed already that came downloaded with the tablet. You can also uninstall apps that you don't really use anymore. You can also see if apps need updated and also if your tablets firmware and system needs updated
Punteggio 7
Aggiungi la tua risposta
Linda Reynolds sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,680
