Salta al contenuto principale
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Domande Visualizza tutte
Temporary repair v-sync cable?
So I opened up my late 2009 27" Imac to install a new hard drive got everything in good but when I went to plug the v-sync cable back in the metal leads on it would scrunch up. Is there anything I can use to temporarily get the leads to stick to the ribbon so I can get it plugged back in?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
It looks like you need Apple Part # 922-9161 if you have the 3.33 GHz machine. You can do a web search for that number or just go here and get it for $19.00: http://www.applecomponents.com/items/000...
Punteggio 3
I used 2sec glue worked fine for me
Punteggio 2
1 Commento:
can you explain exactly how you did this?
da
you didn't need buy a new v-sync cable ...
you can fix it your self with adhesive tape double sided !!!!
you need a cutter and scissors.....
if you need more help don't hesitate !
it's realy easy and FREE !!!
enjoy ;)
Punteggio 0
2 Commenti:
simo, why not explain it on here. That way others with the same, or similar problem, can find the answer as well. It's about empowering each other
da
I agree with oldturkey03 and Diether Busch: I would like to know exactly how you did this. Pictures would be especially helpful.
da
Could you explain how it works with a taper?
Punteggio 0
Aggiungi la tua risposta
nick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,100
