Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Domande Visualizza tutte
Logic Board damage due to forcible Rear Panel removal.
You know how your supposed to GENTLY remove the rear panel, swing it over, and THEN remove the socket connecting the headphone jack board and the logic board?
My friend didn't do that.
When he removed the rear panel, he took the socket along with the connector.
I'm looking at that socket on a good iPod. My eyes hurt because the pins are so small, but I'd like to see if I can perform some surface mount repair on it.
I haven't seen the actual damage yet. On pure speculation, I was thinking of taking a blob of silver solder to each side of the socket, and hope the solder wick works well enough to wick any bridging.
Any thoughts?
Thanks for reading!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Ikvee,
Unfortunately, just throwing a blob or two of solder wick on there wouldn't work. you would need to solder each individual pin down precisely. Thats 10 points, to be exact. If you just throw a blob on there, then there will be shorting due to all the contacts sharing the same point of conduction.
The easier thing to do is to just purchase a new logic board for your device. Unfortunately it looks like iFixit is out of stock (4th Gen Logic Board), but I do know that Rapid Repair has them in stock (4th Gen Logic Board).
Assuming the unit is still open, you will just need to unplug the LCD, Battery, and click wheel ribbons and then remove the 6 screws to get your board out.
I hope that this helps.
Punteggio 2
1 Commento:
+ wise choice. Surface mounted components are hard to replace unless you have the tools and the experience. The Logic board is still readily available, I do get mine on a regular basis from a supplier in China. Never had a problem with shipping or quality.
da
how do i open the ipod
Punteggio 0
how do i open the ipod and with what tool
Punteggio 0
Aggiungi la tua risposta
lkvee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,126
