Salta al contenuto principale
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
bluetooth won't connect to devices
Turned on bluetooth to both phone and tablet but says no devices found even though they are both paired
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would take a look on each device at the ‘paired’ devices list. If you see the other device in the list, there should be an option to ‘forget’ that device. Do this on each device to clear them out. Then turn Bluetooth off and on on each device and try again.
Sometimes Bluetooth connections can be tricky and need a reset.
Punteggio 0
Aggiungi la tua risposta
Rosemary Reed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 379
